Pole dancing
judymac
judymac Member Posts: 403
It appears that we need a pole of some sort for the middle of our PahaQue screened room.
We experience tightness during the heat of the day and adjust the lines; however, totally different during the night and rain and dew collects and it sags horribly.
What are you using that won't tear the fabric?
Thank you.
  • Nomad
    Nomad Member Posts: 7,209
    Don't have the screened room so sorry, can't help there but the Lrg Visor does the same tight/slack routine. Must be the nature of nylon.
  • jkjenn
    jkjenn Member Posts: 6,423
    Thank you.
    I would reach out to Paha Que customer Service, Judy. They appreciate this type of feedback and will help you find a solution. They are constantly tweaking their product to improve it.
  • JandJ92010
    JandJ92010 Member Posts: 304
    We don't have a Paha Que,  so I'm not sure what the situation that you have is, but, could a tent pole with a tennis ball on top help?
  • Michigan_Mike
    Post up some photos so we can see the issue as that will help Paha Que too if it's an issue.
  • Michigan_Mike
    Got a note this morning from Paha Que:    It is an issue with the fabric, we've worked with the mill to try different coatings, without much luck.  We are now trying to source adjustable awning/roof poles to help with this issue.
  • judymac
    Thank you.
