TAB320S interior layout and dimensions?
jcrystal
Member Posts: 32
Looked, could not find a file which showed the floor plan with all dimensions. Does one exist?
2021 TAB 320S Boondock
@jcrystal Try this ... go to NuCamp website, select Tab Teardrop campers, select Menu, select Specifications and you will find some measurements and a layout graphic for the 320S2021 320 S Boondock / 2018 Toyota 4Runner / NE Ohio
Saw that, has some basic info, but what I was really looking for was the measurements on that floor plan, especially the floor between side sofa and kitchen2021 TAB 320S Boondock
Do you need it to buy a rug? Someone just ordered rugs. I’ll bet they measured.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
Found the floor dimensions!
https://tab-rv.vanillacommunity.com/discussion/comment/33652#Comment_33652
BTW - Walmart sells some inexpensive, rubber backed runners and door mats that fit perfectly. Check “Mainstays Apollo”.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio -
@jcrystal floor dimensions on our 2021 320S Boondock
39” bathroom door to side door
24.5” passenger side bench to cabinet under frig
Frig extends out about 2” over the cabinet
32.5”. X 26 “ area between benches2021 320 S Boondock / 2018 Toyota 4Runner / NE Ohio
- 917 Introductions
- 404 Service/Maintenance & Recall Notices
- 74 Teardrop Groups & Links
