Thetford Aqua Magic V not holding water
rhynorhyno Member Posts: 396
edited May 2021 in Products and Accessories
Our month old toilet is not holding water and we can hear fluid dripping into the tank after each flush. We tried silicone spray with no improvement and now we have a replacement blade seal on the way, but I think replacing it will involve pulling and reseating the toilet. This is not an appealing project for our nearly new camper.
Have others had luck with a new seal on this same model, or should we look at a different model of toilet if we already have to pull this one out to do the seal swap?
    @rhyno You can get a RV toilet deal treatment solution, which you pour a bit into the toilet, and it will help the seal to tighten back up. I used some in my TaB, it worked great Cheers
