This forum is definitely a goldmine in terms of learning how to do things, and while I am personally comfortable with electricals, winterizing/dewinterizing, basic fit/finish repairs, and the like, when I read some of the threads on jobs like bearing repacks, plumbing leaks, black tank repairs, or Alde fluid changes, I admittedly feel anxiety building just at the thought of tackling some of those - the dealer can take my money to take care of all that!  It's too easy to feel like we should be able to tackle anything the Tab throws at us based on some very smart/brave people here, but we've all got our comfort zones we're not willing to deviate from.. so what's yours?  And on the flip side, any of you brave souls adventurous enough to tackle absolutely anything to the point where your 'nearest dealer' is irrelevant since you never need 'em?
                1 ·
Knock on wood, haven't needed a dealer's services yet. (Good thing since our dealer is 6 hours away!).
And thanks to this community for tons of tips and pointers and ideas!
It's been a fun education... OMG
Tracked down the 3-way fridge starting anomaly (loose thermocouple)
Replaced the toilet flush valve when we got home
Replaced the thermal fuse on the Alde
Wine time
Screened all openings for wasps and mice
Rerouted the drain under the kitchen sink and Installed a Hepvo trap.
Built a simple shelf under the sink
Installed a GPS tracking device with battery backup for security
Added rooftop tv antenna (still never used!)
And on and on....?
My DW said 'but I thought we bought it new, so you wouldn't have to fix it!?!'
Ok, yes I took it to a tire dealer to get the tires replaced.
However, this is less about being particularly brave or adventurous, and more about many years of incremental experience building houses and wrenching on vehicles as hobbies. All of those skills (not to mention the tools acquired along with them) translate nicely to a camper, which is nothing more than a small house bolted to a vehicle chassis.
There's a first time for everything, and most of these tasks are not particularly difficult if you have the interest and motivation to give yourself a little on-the-job training. (I realize physical limitations may factor in here, too.) It's one of the reasons I gravitate toward the technical discussions here--not to show off my own prowess but rather to encourage others to challenge their own skills. In doing so, I inevitably learn something new along the way as well.
One thing you quickly learn about an RV, any RV is they need stuff and the more you can do, the happier you will be with the RV experience. If you expect to buy one and just have fun and take it to the dealer for every little thing, then you will be here complaining a lot.
1. Changes in my model year that helped me understand I did not have an inverter (the first owner thought there WAS an inverter, but had never tried to use it)
2. Gave me the knowledge to inspect and repack my bearings and adjust my brakes. I felt great satisfaction when I noted the performance when towing improved noticeably.
3. Informed me about a front window rubbing issue between the panes. Nucamp sent a replacement window FREE
4. Informed me about the Jensen radio/DVD and when mine would not load a CD/DVD, I contacted ASA support and when hearing it was a NuCamp product, they replaced the unit FREE despite it being out of warranty. They said "We know NuCamp likes to keep their customers happy".
5. I learned about battery management and that certainly prevented me from ruining my AGM batteries. I installed a budget AiLi shunt and now I am a dedicated amp hour watcher.
6. I learned about proper management of the water systems and sanitation procedures
7. I was informed about how to change the switch on the bath fan, and did it for a couple of dollars.
8. Got great ideas on a mattress topper and sizing of bedding
9. Found out how to take apart the outside shower and reseal with proper sealants, while improving the flow.
10. Discovered a locking ring for the shore power connection that saved a LOT of frustration and time.
11. Finally, gave me the confidence to flush and refill the Alde, on schedule and now is working even better, after I also learned about adjusting the mixing valve for the hot water. I would have never attempted this without the help of others including @ScottG, @Horigan, @Dalehelman
All this and more provided to a guy who is not a technician/electrician/plumber or engineer. And who has low esteem for and no proximity to a dealer. So I would encourage others to read, learn and try some things on their own. It is not that hard and can be very satisfying. Folks here really do have your back!
About as much as I want to do in one year..
I also plan on adding permanent drawers to a couple of the cabinets. I can cut the face of the cabinet and install the drawers, but will purchase the drawer boxes and drawer fronts made to size.
However, my limit of mods has probably come to an end. I probably need a new floor, but I don't have the confidence to tackle that job.
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
