Bclarke
Member Posts: 110
Hello... I am towing my 2021 320 ... after about 1600 miles, when I turn a corner (eg to get into the gas station) my sway bar is very loud. I have NOT backed up ... however I also noted that the connection on the front has been bent upwards. We have had very strong winds today.. I have tried tighten the tension as I thought it was slipping. Any ideas?
defined in the installation instructions.
2) Sway Bar tension is set way too high for weight of T@B
3) Sway Bar 'slider' is damaged/dirty and is not sliding. Installation instructions note the slide bar must
be cleaned after first 1K miles and then every 10K miles to insure smooth operation.
Side Note:
Since most T@B 320 owners do not use aftermarket sway control devices it would be helpful to know your tow vehicle type (short wheelbase vehicles increase trailer sway). And why you decided to install sway control; i.e. bad experience towing T@B?
I have no direct sway control device experience. Prior to owning a T@B past trailers used
surge brakes which can't use friction style sway control. While present TV has long
wheelbase and computer controlled trailer-anti-sway feature so my T@B tracks 100% fine
under all conditions (so far)
Your brand/model Sway Control seems to get positive reviews so installation, usage, or maintenance are your most likely issue. IMHO
If your installation dealer did not provide any documentation.
Attached PDF-File is the Installation Instructions I was referencing in my reply.
I notice in your top picture, the nut holding the ball mount appears crooked? Another fix my new dealer did, was use a longer bolt so I have more threads showing below the nut.
@MuttonChops thank you for the pdf as I did not receive anything either!
Sold 2023 Tab 400
Sold 2018 T@B 320S
Agreed...it should not be tightened unti you can't tighten it further. With the tension handle completely loose, turn the handle until you feel start to feel some tension, then go approximately one to one and one-half revolutions more. That's it. Snug but not battened down.
As for backing up it's really not always necessary to remove the bar. Think about it...you're driving along and must make a somewhat sharper than normal turn, say into a filling station or a city intersection. Do you get out and remove bar before making that turn? No. Then why do so when backing? The bar doesn't know the difference in your direction of travel.
If you're backing into a spot and you've prepared for your backing maneuver such that you're not going to get your rig into a situation where the angle between your TV and the T@B is around 45 degrees or so, there's really no need to remove the bar. Obviously if you're going to have to put the rig into a virtual jack-knife in order to make the swing then yes, it's best to remove the bar.
San Diego, CA
www.airbossone.com
Sounds like yours needs loosened and or cleaning.
Odessa, Fl.
Sorry to bump this after a little while. Is the sway control setup used ones that are bolted onto the frame? or clamped on? Are bolting to the frame acceptable?
San Diego, CA
www.airbossone.com
