AL-KO and Dexter Axle Information
The link below will allow you to use the AL-KO owners manual that was normally provided at purchase.   Keep in mind however that Little Guy has changed axle manufacturers for their Little Guy trailer units and it is always a good idea to inspect  your axle and verify the manufacturer of the axle to ensure that you have the correct information you are looking for.
AL-KO Owners Manual
2200-3500# Axle Information
AL-KO Customer Document Area
1.jpg 133.7K
    edited October 2015
    Here is a bearing maintenance video that will help too, even though it is for Dexter axles.  Both AL-KO and Dexter axle components are now made by the same company as Dexter bought up AL-KO.
    This is a very helpful video and will provide you with some excellent tips for inspecting and replacing the axle components.
    https://youtu.be/GnH-h3W9XvI
    edited May 2021
    Dexter Wheel Bearing Part Numbers
    Description: Current Dexter and generic part numbers for bearings and seals for AL-KO/Axis and Dexter torsion axles with 10" x 2-1/4" brake drums.
    Created by: ScottG
    Posted by: ScottG
    Disclaimer:
     Resources provided by members are not necessarily endorsed nor approved by nüCamp. Models differ and configurations are subject to change at any time. Use at your own discretion.
    edited May 2021
    Dexter Axle Service Manual
    Description: Complete maintenance and service manual for Dexter light axles. (Also applicable to AL-KO/Axis axles.)
    Created by: Dexter Axle
    Posted by: ScottG
