Dometic Thermostat cover causes AC control to misbehave
I attempted to put my AC thermostat cover back onto the thermostat but each time I did it made the control misbehave like scroll all the up or down on the temp setting or continuously cycle through the different modes on the unit. I attempted several times and could not get it to work. I can properly control the AC by pressing on the "tags" on the actual control where the cover would rest. Anybody else experience this?
2019 T@B400
Southern California
Full-timer since 2019
  • pthomas745pthomas745 Administrator, Moderator Posts: 4,503
    I have some older remote controls that flip out when the "pads" under the cover lose a little resiliency and won't "spring back" after being pressed.  Can't tell what those little black "pads" are made of, but they might need a little adjusting, if possible.
  • RMoRMo Member Posts: 162
    Can you slide the base unit up or down a bit, or tighten it down a little more?  Might help.
    2019 T@B 400 (for sale)
    2017 Highlander Limited
