Joolca shower set up
madtrout
Member Posts: 63
I just bought a Joolca shower tent and plumbing setup for an outdoor shower for our 2021 TAB400. The quick connect shower fittings on the Nautilus water management system on the TAB measure .46 inches whereas the Joolca quick connect is .64 inches. Does anyone know of a quick connect adaptor to marry these two systems? Thanks in advance, Mark
2021 T@B400 Boondock
2008 Toyota Tacoma
Silver Spring, Maryland
2008 Toyota Tacoma
You could rig up a short adapter hose, with the TaB male connector on one end and the larger female Joolca coupler on the other end. This would reduce any strain on the Nautilus connection point, and allow for the up from under connection to the panel.
2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast. -
Do you know the spec/size for the TAB quick connect fitting?2021 T@B400 Boondock
2008 Toyota Tacoma
Silver Spring, Maryland -
No, but a quick call to nüCamp should get you the part number for the shower hose plug in part.
Thanks!
2008 Toyota Tacoma
- 920 Introductions
- 74 Teardrop Groups & Links
