Star Gazing window will not open
GrayGhost
Member Posts: 23
I am having a problem opening my Star Gazing window on my T@B 400. The window stayed shut all 2020 (Covid). We went on a trip and the window would not budge. I pushed hard on it from the inside, but no luck. I was afraid to push any harder. Any ideas on how to open? I think the rubber seals are stuck to the body.
Thanks for any help!
@GrayGhost, I think an email to tech@nucamprv.com would be my first choice. Or call your dealer, knowing you will probably be making an appointment to see your dealer.Verna, Columbus, IN
I think that a little silicone spray on the inside at the rubber seal could be tried and should not impact the plastic. We coated our seals with a silicone based protectant for the spring to reduce sticking. But if NuCamp recommends a different approach I would defer to them. Be careful and you should not tear the rubber seal.
Just a long shot, but have you released all the latches on the side of the window?cheers2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast.0
- 426 Service/Maintenance & Recall Notices
