Since we're about off to our first "no water" camping adventure I want to make sure I can add water via the Sanitize method before we leave. Hose is attached & inserted into bucket. Inside trailer pump switch is on. Outside pump switch in on position turns on red light. Only gurgling sounds occur; bucket level does not change.
Edit: Trailer on shore power
What am I missing?
2018 Audi SQ5 + 2021 T@B 400 BD replaces '99 Roadtrek 190 Popular (same mpg with half the range)
No direct Nautilus experience. Have read user manual and various user posts.
First suggestion:
Do not have inside water pump switch On, only use the outside Nautilus pump switch so you have full control of the fill operation.. These two switches are in parallel so the water pump is running if only one of them is set to 'on'.
Second suggestion:
Confirm Alde is in camping season mode not winterized. While unlikely this is direct problem it is one less item to worry about. . . . . . i.e. Have you already used the Adle hot water this season?
Third suggestion:
One more time check that all the Nautilus levers are in correct position and that all faucets are turned off.
Adventures: 52 Nights: 329 Towing Miles 41,900+
