As part of my switch to new LiFePO4 battery, I plan to add a DC:DC charger and am looking for feedback on the various offerings out there. I don't see a need for anything other than a 20 amp unit.
The Renogy gets generally good reviews and is the least costly alternative. The reviews indicate that it performs quite well with the only negatives being the lack of an auto-detect feature (necessitating an additional wire to the ignition side of the TV), and no temperature sensing, which I'm told is not really a concern in the case of Li batteries.
On the other end of the price spectrum are the Redarc and Sterling units. The both appear to be very robust units that work well but are nearly four times the price of the Renogy.
In the middle price-wise is the Victron Orion Tri-smart. It's about 50% more expensive than the Renogy, but the extra money gets your auto detect and BT capability.
Would be great to get more information and feedback from the T@B community on this subject.
It has a limiter you can wire to the positive terminal to set it to 10amps which is what I am currently running and it works perfectly. The quality seems very good and have had no issues. Plus I purchased it for $90 so it was relatively inexpensive.
The alternator's voltage regulation circuitry controls the voltage, not the battery.
Brad
Concord, NC
Brad
Concord, NC
Edit - I was on the complete wrong table, for 12 volts and up to 20 feet, it is rate at 46 amps based on 1/2 volt drop over the distance. Regardless, 20 amps will not be an issue.
Brad
Concord, NC
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
MOUSE-KE-T@B
Harvest, AL
Should we disable the "charging" line on the 7-way, or just leave it? The truck has a standard charge line with isolation relay in the 7-way.
MOUSE-KE-T@B
Harvest, AL
