The anti-rattle pin prevents the receiver ball mount from moving around in the receiver hitch. I hate that clunking noise when going over bumps in the road. The T@B puts more up and down force on the ball mount than the bike rack (obviously) so I inserted metal strapping as a shim as a temporary fix. Will eventually weld some metal on top and bottom of ball mount to reduce the up and down movement as a permanent fix.PXLated said:source3 - What's an anti-rattle receiver pin?
I am partially deaf in one ear thanks to getting hit with Meniere's Disease last year. Thanks for the encouragement though!PXLated said:You just need to get a little older and you won't need that stuff - you'll be too deaf to notice.
TIA!Do you have a 2" receiver or 1 1/2". The 2" generally uses a 5/8" pin the 1 1/2" uses a 1/2" pin.shorthillssummit said:I was told I needed a class 3 receiver lock..I thought that was enough info..well, just got it and it's too big-it's 5/8"..I think I need a 1/2 " but not so sure ..Please adviseTIA!
Another forum I belong to, anything after the question has been answered and 10 posts, derailing is fine and encouragedPXLated said:Derailed thread - Sorry bout that - It's so easy to do :-(
