Tab 320 CS S custom boxes
Looking for locking idea for these custom boxes I order for my 2018 Tab 320
  • Tabaz
    Tabaz Member Posts: 2,420
    After I installed this, I learned that the propane tub needs to be unlocked because of fire regulations. But this would work on your two side tubs.  Simple mailbox lock from Home Depot.
  • Tprim67
    Tprim67 Member Posts: 5
    Thanks !
  • Tprim67
    So it just screws in the lid? And the lock portion hooks under the lip of the box?
  • Tabaz
    You need to drill a 3/4" diameter hole in the top using a step drill like this:
    Make sure you get a lock with a longer shank.  I believe they come in two standard sizes.
    The tab at the end of the lock secures under the metal lip in the body of the tub:
    The distance between the two yellow lines below is critical in getting the tab to go under the lip:
    Hope this helps.
  • Tprim67
    My boxes have no lip any idea ?
  • Tabaz
    The easiest is to pop-rivet a metal "L" bracket to the front of the tub on the inside.  The tab on the lock would then slide under the "L."
  • Tprim67
    Thanks
