Blown 20 amp fuses with generator
Corvairdave
Member Posts: 11
Hello! Newbie here. We have a 2010 T@B and recently bought a generator. Honda 2000. I seem to be blowing the 20 amp battery fuse whenever we use the generator. Any help would be great! TIA Cheers, Dave
@Corvairdave, your battery fuse (both at the converter and the battery connection) should be 30A.
Regardless, to use a generator like the Honda 2000, you need a Neutral-Ground Bonding Plug (N-G Bond.) I am attaching a couple WORD documents that describe what I am referring to. At the end of one of the documents it shows how to make one. You can also search YouTube to find a video that shows you how to make one. It is easy to make, which is what I did, but they are inexpensive to purchase, so you can go that route as well. You insert the N-G Bond plug into one of the generator's unused 20 amp outlets and the T@B electrical cord plugs into the other outlet.
2019 T@B 320 S Boondock Lite; 2025 Toyota Tundra CrewMax 4x4
Greg & Marlene (Tucson, AZ) -
Thanks so much! Ordered and on it's way. Big help. Cheers, Dave
Just re-read about the 30 amp. I'll check into that!
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
