Replacement trim 2016 t@b 320
NMcamper
NMcamper Member Posts: 3
edited July 2021 in Trailer & Towing
I apparently had a rock hit the trim above my aluminum diamond plate on the front of my 2016 t@b 320. It looks like a slide in trim that fits in a channel. Has anyone had this happen and how difficult is it to fix on your own. Thanks for any assistance.
—Admin note—changed year of T@B to 2016, rather than 2026…..Verna, T@B Admin
    Welcome, NMcamper.
    As with the plastic strip that comes installed in the keder rails, I'm guessing that covers a track with several exposed screw heads. There are different styles of such trim, but you probably want something like this. They should snap out and snap in, so you shouldn't have to remove any other trim to get it replaced.
  • CharlieRN
    CharlieRN Member Posts: 436
    I can't help with the question but did want to say that I'm impressed you could get hold of a 2026 model T@B . . .
  • Mouseketab
    Mouseketab Member Posts: 1,262
    That is common snap in trim. I installed Diamond Plate on my Dutchmen T@B, and that trim was part of the "kit" I bought from Pleasant Valley.
    Carol
    MOUSE-KE-T@B
    2022 nuCamp T@B 320 CS-S
    Harvest, AL
  • NMcamper
    Sorry I posted that from my phone and I have old eyes. Thanks for correcting it Verna.
  • NMcamper
    ScottG I think I will order what you recommended and see if I can get it to work. It covers screws just like you described. Thanks for your help.
