Removing front bezel on Jensen cube?
CanadianTabber
Member Posts: 148
Hi all!
Does anyone know how to remove the front bezel on the Jensen cube?
I want to gain access to the power lead so i can switch it and its annoying display off at night.
Thank you!
Brent
Thank you!
Brent
Toronto, Canada
Toronto, Canada
Not sure which model you have, so here is a link to the Jensen installation manuals. Hope this helps.
https://jensenmobile.com/user-manuals.html
2024 Ford F150 Supercrew short bed.1 -
I don't know if the new models differ, but my entire unit could be removed from the cabinet after removing four screws on the face. A wiring harness in the back of the unit included the main power line.2015 T@B Max S (320)
The screws are likely under the bezel..here is what it looks like.
Toronto, Canada0 -
I would try a plastic putty knife to lightly pry the front bezel off. Expect to find Robertson or square drive screws under the bezel.I intend to put an inline switch next to the Jenson as I don’t use it. Less phantom draws on the battery system and no light from the Jensen at night.Verna, Columbus, IN
I will try that Verna..thank you!
Brent2021 Tab 320s Boondock-2016 Toyota Venza V6
Toronto, Canada1 -
FYI you could dim the Jensen cube to zero then toggle the display on and off by tapping the power button. That's what we are doing until I get the time to install a power switch to kill the phantom draw off the batteries.
2021 T@B 400 BD, 2021 Lexus GX 460, Kansas City MO2 -
I did try to do that rhyno, put couldnt get it to dim fully...will try again but like you, I want to kill the draw.
Toronto, Canada0 -
Success!..i was able to gently pry off the bezel quite easily and remove the 4 Robertson screws to take out the unit.
I will be putting a small toggle switch on the panel to the left of the radio with the toggle out of sight in the small cubby there...thanks for all the help everyone!
Brent
Toronto, Canada2 -
Yeah, that's way different from mine. Glad you got it figured out in either case!2015 T@B Max S (320)
Btw, here is the manual2021 Tab 320s Boondock-2016 Toyota Venza V6
Toronto, Canada0 -
Hi,
Do you have a picture of the switch or brand/part number you used? I also would like to have the light completely off at night. Thank you2025 360 CS
Southern Maryland0 -
Yoshi_TAB, I used a toggle switch i had kicking around.
I drilled a hole the size of the switch shank and inserted it from behind with wires already attached. Because the switch shank was not long enough, i just epoxied it in, cut the red wire and crimped the switch wires to the two red wires...simple but effective!
Here is the pics🙂
Toronto, Canada0
- 76 Teardrop Groups & Links
