Help please--camping right now with hookups-- went to make coffee & little electric coffee pot doesn't work-- tried other outlets & they are dead too-- tried another electric appliance-- same thing. The USB ports right next the outlets work-- overhead all lights work-- alde working on electric & fridge working. Checked & reset button-- checked electric panel-- no lights indicating a fuse is blown. Ideas??? 2017 Tab 320S
2016 Nissan Frontier SV V6 4x4
Finally! New Owner of a 2017 Tab 320S!
Woohoo!
0 ·
Is your cord plugged in tight at the pedestal and the side of your camper?
Which brings up another question-- if I'm plugged into electric should I shut off my battery disconnect?
Woohoo!
Then as others have noted the GFCI Outlet has tripped or the 120VAC Outlets Circuit Breaker has tripped.
GFCI outlet can be difficult to reset, Circuit breaker should be toggled full off then back on to confirm it has not tripped.
While every T@B may not be identical. Typical 120VAC Wiring is:
Adventures: 51 Nights: 322 Towing Miles 41,200+
Woohoo!
