This may have already been discussed but instead of using the inconvenient HDMI port on the Jensen unit, I rigged up a way to have our Amazon Fire Stick attached to the back of the TV with an HDMI switch inline. This will let you still use the Jensen’s HDMI port on the front of the unit and still have a streaming device always attached and ready. The switch is maybe $10 and the install is dead simple.
HDMI Splitter 2 in 1 Out 4K 60hz HDMI Switch 2 in 1 Out, HDMI Switcher 2 Port, No Power Required, Sharing HD Video, PC Gaming Accessories https://www.amazon.com/dp/B085DKZX2B/ref=cm_sw_r_cp_api_glt_fabc_Q8J5G8NCBBB4PKN3V3J7?_encoding=UTF8&psc=1
2020 Tacoma TRD Off-Road
While is might be too nerdy for most folks, I used a Raspberry Pi to build a Kodi server with hundreds of hours of old TV shows, movies, music, and audio books on it. No signal needed.
I also use an HDMI switch like the one in this thread to switch between sources.
Jeff & Amy
We decided to go with an iPad mini for this task. It works with many android tablets or phones too. Just make sure you have video output capabilities on your device (our Motorola phones wouldn't work, for example) and the correct adapter. There are discussions on the forum about what different folks use.
2019 320 Boondock Edge - Sold Jan 2022
Good to meet you at UCamp.
Jeff & Amy
https://smile.amazon.com/gp/product/B07QWTY3VV/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1
Thanks, Jerry
Jericho, VT
https://www.lifewire.com/connect-usb-drive-to-firestick-5201861#:~:text=Connect the Amazon Fire TV,USB drive has been detected.
2020 TAB 320 S Boondock Lite
2019 Toyota 4 Runner
Puget Sound Country
