Aeroflo Installation on 2021 T@B 400
Quick question for the forum. I know much has been posted on this topic, but I think the answer might be specific to year, model, and fan, so I want to make sure I'm not referencing a post that might not be correct for my specific combination of the above.
Installing the Aeroflo requires drilling 4 holes in the vent frame. On the OEM Fantastic Fan on a 2021 T@B 400, are there any wires running inside the frame at these 4 vent frame corner locations that I need to be aware of before I drill?
Thanks in advance,
Cheers,
C
2021 T@B 400 Boondock 'Valhalla'
2018 Jeep Grand Cherokee Trailhawk V6
veni, vidi, bibi capulus
  • Grumpy_G
    Grumpy_G Member Posts: 766
    Not familiar with the specific fan installed on the 400 but generally speaking the corner that has the controls in it is of concern. If the fan is continuously variable there is a little PCB in there. IIRC the Aeroflo has slots to connect to the mounting brackets so move the bracket as far away from that corner as possible.
  • jdjaustin
    jdjaustin Member Posts: 2
    TT: 2021 T@B 400BD | TV: 2021 F-150 PowerBoost
