Site access issues - certificate expiry
I'm not sure if I'm the only one getting this error message when using Firefox or DuckDuckGo to access the forum:
"Websites prove their identity via certificates, which are valid for a set time period. The certificate for tabforum.nucamprv.com expired on 7/23/2021.
Error code: SEC_ERROR_EXPIRED_CERTIFICATE"
I've gotten this on both my laptop and desktop and in both cases, after checking and re-syncing the computer clock. The MS Edger browser does not return the message however, and connects to the forum normally.
    Sharon_is_SAMSharon_is_SAM Administrator Posts: 9,497
    No problem here using Safari via the Vanilla url.  Are you accessing via Vanilla or via the nuCamp website?
    I'm not sure why you're using that domain, but I use: tab-rv.vanillacommunity.com
    Try that?
    CharlieRNCharlieRN Member Posts: 439
    edited July 2021
    It's odd - I did not change the domain, somehow Firefox/DuckDuckGo chose it and I didn't realize it was not what I had been using. No problems using  tab-rv.vanillacommunity.com.
    Thanks for the suggestion
    I'll guess that error means an expired certificate at nuCamp.
