Bought this T@b last year in Sept and only used it one time. Refrigerator was working at that time on AC electric - didn't try it on gas. This year, can't get it to cool either on AC or gas. Getting ready to go on a short trip, I did something, not thinking - with the trailer in front of my house, I connected to house power and turned on the refrigerator AC power option (selected the AC option and set AC temp to the highest setting) and the key point here is that my house is on a bit of a hill so trailer was not level front to back. Let it set there with the AC option on for a few hours and it didn't cool. Realized the error of my ways, so got the trailer level in a different location and tried to get refrigerator going on AC first - it actually, at one point started to cool - the fins inside were cold - but then it didn't continue to be cold. Then with trailer level, again, I tried gas option and refrigerator would not cool. For the AC option, I confirmed power to outlet under the sink and made sure no problem with breaker and that GFI not tripped. I haven't checked the fuse on top under the cook top yet but thought, since it's not working on either AC or gas, that's not likely the problem. Norcold manual says, if try to run refrigerator when not level, damage to cooling system cold result. Is it likely that's what has happened? Other thoughts?
2018 T@B 320S. Tow vehicle: 2020 Toyota Hylander Hybrid
0 ·
Expect no one has jumped in with answers/solutions as there are so many unknowns . . . I don't think there will be a clear answer, just ideas & guesses. Some of the unknowns include:
- Just how steep is the driveway. Most Norcold Fridges can operate safely with as much as a 6-degrees front-2-rear.
- Believe this is a new to you 'used' T@B so how the last owner used or abused the Fridge is unknown. In general web-articles state operating the Fridge out-of-safe-level results in a slow death of the Fridge. You don't know if your driveway event was the first or typical for your Fridge.
Fridge temperature. Do you have a thermometer in the fridge? The 3-way Fridge takes forever to
get cold . . . like overnight operation. Checking a thermometer every few hours is better than just opening the door and touching the inside.
No 'AC on' indicator. The little lamp is known to burn-out. As you know there are also fuses under the stove top, one of those [3A] is for AC operation.
Adventures: 58 Nights: 405 Towing Miles 50,180
Huntington LI
https://tab-rv.vanillacommunity.com/discussion/6748/update-2018-norcold-3-way-model-n180-3-ac-indicator-light-defective#latest
Huntington LI
@jalars8 yr-2018 T@B has the 3-way model N180 which replaced the 'green light' with a gauge.
The issue could be that it is just too hot to cool down, or there is no refrigerant. The lack of indicator lights or trailer not being leveled is of no consequence because you indicated you feel heat coming out of the upper vent so your fridge is operating on propane or AC, ie: it is heating up the ammonia.
I think it's more a case of overheating the evaporation chamber where the refrigerant should be, but isn't because of the angle.
Here's a discussion about it: https://www.rvforum.net/threads/how-long-is-safe-to-leave-fridge-out-of-level.106056/
I expect someone with a better understanding of absorption refrigerators can explain it more accurately, but my experience was that it recovered after I let it completely cool down and leveled it.
TV 2025 Telluride X Type
I used a USB splitter to join the fans and connected the splitter to a USB extension which I ran thru the front window into the Jensen USB port.
Huntington LI
ELUTENG 120mm Fan Cooling Transparent USB Desk Fan with Blue LED Light 5V Ventilation Fan Clear Compatible for Receiver,
Poyiccot USB 3.0 Splitter Cable, USB3.0 Male to USB 2.0 Female & USB3.0 Female Y Splitter Charger Cable Power Cord Extension Hub Adapter for Car / Laptop / LED
I have just completed adding two USB Power Fans to my Fridge Exhaust.
I'm using smaller fans, 80mm 1500 RPM. They create a little extra air flow.
Ran the USB cable across Fridge top (below stove) around inside of sink cabinet, then up the shower wall side 'factory wiring space'. Will just plug USB cable into outlet above Sink when fans are needed.
