The Alde is a gradual learning curve. This past trip we had full hookups using the electricity to heat the hot water. We had it on 2kw and highest setting on the temperature (icon of showerhead) but we were only able to get maybe 5 minutes of hot water for showers. Is that normal? I’ve yet to fuss with the mixing valve so maybe that’s it but how long of showers are people able to take? I thought the Alde Flow tank allowed for continuous hot water.
2021 400 BD
2020 Tacoma TRD Off-Road
0 ·
With all of that being said, we can take virtually an unlimited length of showers if we are connected and don't need to conserve water, which rarely happens. We take "Navy showers" IE get wet, pause the water, soap up, then rinse.
Not sure if this helps you or not but maybe it explains a little of the Alde better. Yes, there is a bit of a curve but it is by far the most efficient heating system I have had in any RV I have owned. In fact, it was one of the primary factors of buying a 400 when we upgraded from our 2017 320-S. When you boondock and do it in cooler weather, it is an amazing system that works great and is very efficient!
Brad
Concord, NC
In our case, and for many others, it was more than just the mixing valve adjustment (the official 'hack' of turning the valve above its factory preset). It was also making sure the Alde pumps (both of them) were set to the same level. Once I set them both at 2, we get nonstop hot water.
We have not showered in our 400 yet, but have seemingly unlimited hot water like we do at home with our tankless hot water system.
Donald S. Cherry - 2016 Kia Sorento V6 (3.3L)
Where we call home - Our House, Calgary, Alberta, Canada, North America, Earth, SOL, Milky Way, Universe
GO FLAMES GO!
Sounds like yours is working as intended. We always have plenty of hot water for washing dishes but that's due to the lower flow of the kitchen faucet. I did notice those high temps in the panel settings (under "service"). I think we were at 170 degrees at one point for the water and glycol.
Can you point me to a discussion about those pumps? Is that something you can set on the panel?
@manyman297, If you don't have the Alde Flow option, you will have limited hot water. Changing the pump(s) speed really won't affect that. You're best bet is to vary the mixing valve, but again, you're still stuck with a two gallon hot water tank to shower with.
I have the alde flow unit. I've made sure it is selected as an option in the panel. I'll have to look at the pump setting.
@webers3
Haha, I have luxurious demands
Nope. Get wet..turn off shower. Lather. Rinse. Done.
This ain't the Ritz!
San Diego, CA
www.airbossone.com
Tried it again today. Using propane I set it to 2kwh (manual says to do this regardless of if you are using electricity or propane), turned the hot water setting all the way up (“more hot water” setting) and I was getting 117+ degrees of hot water continuously for a little over 10 minutes. Plenty of time for my needs and that’s too hot for a shower so I’m sure you could stretch that out even longer if you wanted to.
Looks like this is the Ritz after all.
San Diego, CA
www.airbossone.com
