SUGGESTIONS WANTED. My 2011 T@B has been sitting in South Fork CO for nearly a month as the RV service manager tries to locate an axle with hydraulic brakes. It's a long story, but the bottom line is that I need it repaired. They refuse to install a used axle, they refuse to install an electric-brake axle, and they refuse to convert an electric axle to hydraulic! I've posted this on other sites, but do not yet have a practical solution. Any suggestions how I might help them find the OEM axle, or how I might push them to some alternative solution?
Might be helpful to list out the various suggestions, from your Facebook post, that have been researched and rejected with why rejected - - .
That way this thread might lead you to a New Solution Faster then getting all those rejected options re-discussed.
2011 T@B
Rockingham, NC
the RV dealer was I-5 RV Sales and Service. They are a long way from Colorado but they may know of someone in Colorado ?
I have a question… I bought used and there are NO trailer weight rating tags anywhere on the vehicle, not on the tongue or interior of the T@B.
could you possibly share the numbers on your rig ?
I have the U-Shape interior, no shower. It’s gotta be pretty light, maybe 1600 lbs, but I don’t know the payload weight or the GVWR…
thanks.
2011 T@B
Rockingham, NC
The axle actually slipped forward causing door side tire to rupture.
They took off the axle off, rebuilt, stress tested and reattached just behind original position. The guy explained it was never installed properly.
Thanks again,
Barbara
2011 T@B
Rockingham, NC
