Hi Tabbers
I have a problem with my fridge (3way) when I switch from electricity to propane (code 3 appears on the screen)I tried over and over again same results:
1-I have full of propane
2-valve in open position
3 -I hear the pilot's ciick click!
im in Canada right now and no dealer anywhere ... the fridge is new (1.5 month) never been used on propane ... nucamp has installed a new fridge beginning of June but it was for another problem which has nothing to do with the problem I have today!
I need your help guys!
Thanks Harold B
a) Make sure you have good gas flow at the stove. Then try getting the Fridge to start on propane several times with an 'Off' in between each attempt, this is included in the Norcold 4000 Troubleshooting section. Could take a while to clear any air from the gas line to the Fridge.
b) Might try setting the Temperature to Maximum before or while the 'sparker' is running. Telling Fridge to get super cold while in propane mode means the internal gas valve would be wide open.
c) User Manual discusses the fire box access, you might open it an try match lighting the burner - - using great caution and completely at your own risk
Adventures: 58 Nights: 405 Towing Miles 50,180
(1) propane tank is full
(2) I ran the stove for more than a minute
(3) I verified that the igniter is creating spark by removing the exterior vent cover and looking in the ignition peep hole
(4) I repeated the on/off troubleshooting process per the user manual at least 20 times and the error code 3 kept returning
I am wondering if anyone knows what this screw is for on the propane connection. I was hoping maybe it’s a manual bleeder valve or possibly a regulator for the fridge propane. It is located behind the fridge and can be viewed by removing the exterior vent cover outside the camper
When the Flat Tip Screw Driver Slot is vertical the Gas is OFF
I do not know if your picture shows the valve as part open or fully open.
One might assume when the Flat Tip Screw Driver Slot is horizontal the Gas is fully ON.
Juliet and Andy in Massachusetts
they are very cautious about offering any DIY solutions with propane. It makes sense, I guess.
The knob is a manual shut off for the propane, apparently…
” No the brass knob on the gas valve is to open and close the valve manually [not a bleeder]. But if they are getting a 3 code that is something that would have to be looked at and diagnosed by a service center. It can be a number of things for that code.”
