Using screws in 2021 320S bathroom wall?
I attached a larger toilet paper holder using Command strips with Velcro to the bathroom-TV wall last year. It was fine until this summer’s heat. It is pulling the wall covering away now.
I’m a little confused from earlier posts. Can I use screws to attach things to that wall?
2021 320 S Boondock
Subaru Outback XT and Honda Passport
Des Moines, IOWA!
  • andyboy
    andyboy Member Posts: 120
    Thanks @Sharon_is_SAM. I was hoping this is what I would find. Fingers crossed for my non-handyman skills. I’ll report back!
    2021 320 S Boondock
    Des Moines, IOWA!
  • Homebodyatheart
    Just a FYI, here’s a pic of a section of your Azdel outer walls, so you know what you’re dealing with. Looking forward to seeing your mods!
  • JustSuper
    JustSuper Member Posts: 2
    I know this thread is long since expired, but I just installed an Ikea Kungsfors rod that had been held on by command strips, but of course it wouldn't stay... This wall will accept self-tapping screws, but don't use screws any longer than 5/8" -- MAYBE 3/4", or they will poke through the other side...as I found out. However, it is solid now. FYI, This is the wall next to the sink that is shared with the bathroom.
    Hope this helps someone.
    SpartaPanther
    2021 T@B 320s
