Exoskeleton on a T@b 320 s Boondock
avillaravillar Member Posts: 1
edited November 2021 in Trailer & Towing
What are the uses for the Exoskeleton on the T@b 330 Boondock and can you stand on it (weight limit?)?
    edited August 2021
    A clothesline and it takes the hit when backing up too close to a tree. That’s all I can figure it is for. It’s there and I don’t think too much about it since it comes with the model.
    No way would I put any weight on it other than clothes.
  • SusanDSusanD Member Posts: 87
    You're talking about the metal frame at the back by the lights?  I've climbed on it a lot to put up my lights or put some little solar panels on top.  At 110lbs, no problem at all.   But I suspect it will also make a very good clothesline.
    2021 Tab320S Boondock, 2019 Subaru Outback 2.5
  • Rodent77Rodent77 Member Posts: 80
    Used mine for tarp attachment...
    2021 T@B320 S - 2013 Ridgeline - Ont. Can
    Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming WOW! What A RIDE!!”  Dr. Hunter S. Thompson
