Today was a day of towing with many firsts. First time towing with a body on frame vehicle. First time towing with some decent crosswinds. First time towing with a nice V8
Tab 320S loaded with most of the trailer loaded forward of the axle, including full main tub and side tubs.
TV: Ram 1500, Crew cab, Short bed ... weighing about 6200 lbs or so.
What I noticed today was interesting. First the body on frame meant the tow felt solid and I certainly felt less of the trailer through the body of the vehicle, like it was on my Volvo. Next, when going above 60mph or so and the crosswinds hit, I could see the trailer swaying a bit before the gusts would die and the trailer would settle down. Expectedly, there was zero drama in the truck and if I hadn't been watching the side mirrors, I wouldn't have known of the sway. This is of course expected with the wheelbase and the weight ratios of the TV and Tab.
That said, I was curious as to
whether a sway bar would help calm things down in these cases? I'm assuming of course that the trailer had proper tongue weight- there was no sway when the crosswinds were calm. The one downside that I foresee is losing my adjustable hitch setup that I have dialed in.
My experience with the GM version of the feature is that it works well and I only notice trailer sway under very rare and abnormal conditions.
Have not heard of very many owners with Stability Control Trailer Sway Control feature adding a sway bar to the trailer.
Adventures: 55 Nights: 376 Towing Miles 46,920
Am sure there are limits but for typical highway and typical cross-wind conditions the Engineers came up with a neat and reliable system.
Curious though how your 1500 is 6200 lbs. My Ram 2500 is 6300 lbs empty....
Brad
P.S our 2020 400 BDL does the same behind our 2017 F-150. Yes, I know that my signature shows a 3/4 ton diesel that was supposed to be delivered 2 months ago now.
Concord, NC
You also need to to have the Tab level or slightly nose down. Towing nose up can lead to sway problems. I tow with a 2018 Jeep Wrangler Rubicon, so the drop of the hitch is fairly long to get the Tab level. Mine does not sway at all.
WilliamA
2017 T@G XL
2020 Tacoma TRD Off-Road
I found it best to experiment a bit and what works best for me is: load TV with heavier gear on or in front of rear axle (except the large Bison cooler...gotta have quick acces to that!); use friction anti-sway; fill H2O tank (full...otherwise it will slosh from side to side); holding tanks empty (except perhaps when attempting to "clean" the black tank while travelling); max speed 60mph. Seems to work...Otto tracks like a hound-dog on a scent.
I do wonder if and to what degree an deflector mounted on the front of the TV roof rack would do any good. Concern there would be vibration and wind noise in the TV.
Anyone?
San Diego, CA
www.airbossone.com
