Inline Fuse on Battery Positive to Charge Controllers??
Jax0913
Member Posts: 70
Hopefully a quick question... We have a 400 with 200watts of flexible Renogy panels installed on the roof our tab running to Renogy Rover Elite. I have an inline fuse on the positive side of the panel coming into the controller. I just added a SAE port on the side of our under storage and a 100watt Suitcase with extension cables. I ran this to a Renogy Adventurer controller with another positive inline fuse coming in to the controller. I have the bluetooth 1 connected to the adventurer and the bluetooth 2 connected to the rover. I was hoping to use the communication hub to link my panels up but it wasn't compatible with the adventurer. Do I need fuses on the positive battery cables? Also, anyone have a better bluetooth set up?
2018 T@B 400
2020 Toyota Tacoma Double Cab
From all I’ve learned in the past 6 months, you should have a fuse on the positive between the controller and the battery. You should also have a way to disconnect the solar panels when not needed - a switch or breaker or a way to unplug them. I can’t help with the Bluetooth.2019 T@B 400 (for sale)
2017 Highlander Limited -
@Jax0913 Here are a bunch of citations, all recommending a fuse. I used a circuit breaker so I could use it as a switch if necessary
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
