Ok kids, this could be long.
Also, I'm not an engineer, nor do I play one on T.V. :-)
Having read all the posts about the Danby dripping and how to prevent it, I deciding to have a deeper look. This is my quest:
I pulled the unit after a trip and silicone caulked all around the inside of the a/c compartment thinking maybe there was a crack or something.
Nope. That didn't do the job. Besides, there was little evidence of there ever being much condensate in the pan. Drain was clear, too.
Next trip was high altitude in Co. where we dry camped for a week. The 3-way fridge worked flawlessly on propane.....and we were dead-to-rights level. No need for A/C. This got me thinking, well, what if you want to use your fridge on propane AND your A/C? One needs level, one needs tilting. Now I don't know to what extent being out of level will affect the fridge, but I'll leave that for others. Point is, it got my mind going......not always a good thing. Things break. :-)
A/C Primer: Air conditioners condition and cool the air. Conditioning is pulling out the excess moisture. This collects on the front (inside) coil and drips off and runs toward the back. It's this water that is the problem.
Most window a/c units have what's called a slinger blade on the fan in the rear of the unit. This is something I just learned. Never came up on any forum discussions that I could find. That's why I'm bringing it up here. Anyway, this slinger blade picks up the condensate (water) from the pan (bottom of the unit) and basically slings it at the coils in the rear of the a/c. The affect of this is to increase the efficiency of the unit.... like perspiration on your arm. NuCamp drills a hole in the bottom of the units to drain this condensate into their pan and out the drain. Danby does not come with a drain hole because of the slinger blade. BUT, as these units are installed inside, spraying water wouldn't work too well.
Now my theory is this: The opening that the factory has cut for the a/c is plenty wide.....I assume they thought they were giving the unit plenty of access to outside air, plus the little computer fan up above the unit helps, too. However the top and bottom of the opening encroach on the rear coils by about two inches. Probably not significant until you remember the slinger blade. I think, it's throwing condensate against the trailer wall at the bottom where it is able to end up running down past the factory pan and also any caulk, and down the wall onto the cushions........unless the trailer is tilted to the front and passenger side. There is a bit of a moat formed in the metal pan that can hold water for the slinger blade and keep it from draining out the hole NuCamp drilled.
So there you have it FWIW. And this why I want to put the a/c on glides and push it outside. It will be way more efficient!
Tom & Susan & Della
2017 320S / 2015 Tacoma TRDSport
0 ·
For a typical 320S Boondock with 15-inch wheels and a Coupler Ball Height of 16-inches if starting at 100% level you would have to drop the coupler by 5-inches to cause the Fridge to be greater than 3-degrees out of level. For the A/C unit you only need a slight coupler lower than level to cause water to drain toward the A/C catch pan drain hole.
Adventures: 51 Nights: 322 Towing Miles 41,200+
I understand. Actually, most times when we'd be using the a/c, we'd be on shore power.....as would the fridge, so the whole level thing is kinda moot. But it got me to thinking about where these a/c units are leaking. The biggest discovery was the raised moat around the rear fan and it clearly has gotten full of water. The holes that NuCamp drilled are on the wrong side of that moat. I submit that if one were to drill a few more holes in the moat area, 1) there's no water for the sling blade to pick up and 2) tilting the trailer becomes unnecessary when using the a/c. I sincerely doubt the factory pan would overflow unless the drain is clogged.
But that's too easy. I'm still thinking about glides. Lol
Ok? Clear as mud? :-)
The sodium chromate is to used for 2 purposes.
1. Increase the efficiency by helping provide a place for the coolant mixture to collect back as a liquid
2. Provide protection to the refrigerator plumbing from the caustic refrigerant mixture
Brad
Concord, NC
Brad
Concord, NC
With the advancement in compressor technology, batteries, and solar charging; it is of my opinion that the RV Industry a a whole should quit using absorption refrigerators. I have had 3 previous with absorption refrigerators and it seems like they were always too warm or they were freezing everything in the refrigerator, including the 2017 320-S we had previous to the current 2020 400 BDL with the compressor refrigerator. Funny thing is, when I bought the 400 the dealer had both. My main reason for not getting the larger refrigerator was that the 320-S was a pain in the butt to get the propane lit and I was just tired of fighting a refrigerator instead of enjoying myself. Going with the smaller compressor refrigerator ranks in the top 10 best decisions I have made, okay maybe the top 25.
Brad
Concord, NC
Before condemning it, I would consider having a trained and competent RV technician look at it.
Brad
Concord, NC
So, are you going to test your theory by drilling those holes to see what happens? I guess you'd need to run it in hot humid weather for a while to make sure you're getting the water dripping near the window, before you drill the holes & retest, while maintaining the same trailer leveling for both. Let us know how it goes.
I believe that a lot of people either replace with a compressor style refrigerator or use coolers when they die.
I wish you the best of luck getting it operational!
Brad
Concord, NC
