how to improve fridge cooling for 2013 Norcold with one fan
Mellow_YellowMellow_Yellow Member Posts: 354
My 2014 T@B Max has a wonderfully reliable Norcold 3-way fridge. This model of T@B has just a single vent beside the door and the fridge is equipped with one fan. Is there a way of adding an additional fan? Would an internal, battery operated fan inside the fridge improve cooling? Would it be worth adding a fan to the side vent? Here are examples I have found:
Interior fridge fan: https://www.amazon.ca/Valterra-A10-2606-FridgeCool-11-28-Switch/dp/B002N5W8Q4/ref=sr_1_4?crid=2P90ZN66OJWA&dchild=1&keywords=rv+fridge+fan&qid=1629575009&sprefix=rv+fri,aps,253&sr=8-4
Add-on fan for side vent: https://www.amazon.ca/Waterproof-Moisture-Proof-Airflow-Cooling-3500RPM/dp/B08KXQT6DT/ref=sr_1_8?crid=2P90ZN66OJWA&dchild=1&keywords=rv+fridge+fan&qid=1629574474&sprefix=rv+fri,aps,253&sr=8-8
The problem I am trying to solve: During recent, abominably hot weather, running the fridge on propane, the fan was not keeping up and draining my battery like crazy. So I turned off the fridge to avoid overheating it and draining my battery during the hottest part of the day.
