Setting Air8 temperature
I have not yet camped with electrical hookup, so had no experience with A/C. Today I plugged into house power to use A/C to dehumidify. Turns on fine, defaulted to 72.5 degrees. I push the left arrow to lower temperature and "set" flashed upper left of screen, but for the life of me I cannot find which button to press to "set" the new temperature, and it goes back to the default after a few seconds. Manual of no help. Stupid question, but help please!
2021 TAB 320S  Boondock
  • jcrystal
    jcrystal Member Posts: 32
    As I mentioned in the subject line, it is an Air8. I have a 320s....didn't know the control unit differed on the 400.
  • Verna
    Verna Member Posts: 6,876
    I am so sorry—it was smacking me in the face and I didn’t see it. My goof is deleted.
    I will admit to not have delved into the manual much on my Air8, choosing to just to figure it out as I go.  I pressed the left arrow button to take the temp down, and the right arrow to take it up.
    I know there is a sensor that may need to be moved and that there is an update to keep the fan on. I admit to not doing either as the first time I used my Air8 was a few weeks ago when it was over 100*F inside my T@B after traveling all day.
    I will bow to those who have had more experience with the 320’s Air8…..
  • MikeDawn265
    MikeDawn265 Member Posts: 29
    I don't believe you can change the temp setting when you are in "Dehumidifier" mode, only when in "AC" mode.
    Wisconsinites 2020 T@B 320 S - 2021 Dodge Durango GT Plus TV
  • Mobean
    Mobean Member Posts: 76
    There are no stupid questions.  I am new to the 320S myself.  The Air8 manual is a little unclear and settings are not intuitive.  Here's a video that will help you with the set up process.  https://www.youtube.com/watch?v=0aC0Wu5XqI0
    Here's another link to different thread on controlling the inside temperature that may be helpful.  https://tab-rv.vanillacommunity.com/discussion/11435/elwell-sent-me-a-temperature-probe-and-harness-just-installed-it
    I contacted the Elwell corporation.  They are sending me a remote sensor with instructions at no charge.  Enjoy your TAB!
    2021 320S BD
    2020 V6 Chevy Colorado
