Eliminating Tab 400 Rear AC?
rrcbov
Member Posts: 109
One night in a moment of frustration over the rear AC duct that blows at the side of my head, I removed the register and stuffed a towel in it. Turns out this works for me temperature wise. So my question is, are there any unintended negative consequences of blocking off this duct? I see three approaches. 1)something more elegant than the towel that’s in it now; 2)block it at the manifold on the CoolCat; and 3)remove the duct from the manifold and let the cold air flood the compartment under the dinette seat where the CoolCat lives.
2021 Tab 400 Boondock, 2021 Toyota Tacoma, Juno Beach Florida
I would block the duct at the wall in the bedroom area. Resale value is a good reason. We all say this is our last T@B (yeah, go ahead and laugh, @ScottG!!), but sometimes life throws us a curve ball. Don’t make a change that you will have to explain to a new owner why you didn’t have time to put it back k the way it was.My opinion is based on seeing a lot of new buyers last year who have already sold their new T@B’s within a year of purchase. Life changed, jobs were lost, had to follow a job, pandemic is slowed down and they can fly again—lots of valid reasons.Verna, Columbus, IN
I think it’s designed with three ports in mind. So blocking off one may cause too much positive pressure in the system and burn out the blower motor. Not totally sure about this though.2021 400 BD
2020 Tacoma TRD Off-Road1 -
There may not be enough air flowing across the coil that it may ice over.2016 320 CS-S 1954 Ford F100 2017 Chevy suburban 2023 Chevy Silverado 15001
I also dislike cold air blowing directly on me. By rotating the duct cover 180 degrees, the air now blows upward over my head - which works for me.--Marlee
2021 Tab400 Boondock; TV 2025 Jeep Grand Cherokee Limited; Minnesota1 -
Spin the duct and/or damper it. I would be reluctant to block it entirely.2020 T@B 400 "OTTO" (build date 08/19)
San Diego, CA
www.airbossone.com
https://fineartamerica.com/profiles/owen-ashurst/shop1 -
@manyman297 How is your rear A/C register mod working out?2021 TAB 400BD; 2015 Audi Q5
Boston Northshore1 -
I haven’t modded mine. I just point it up and let the cool air fall down.
2021 400 BD
I sent Dometic this question on their support form. I’ll share the response when I get it.2021 Tab 400 Boondock, 2021 Toyota Tacoma, Juno Beach Florida1
Check out my diverter fix. Details here and it works great.
https://tab-rv.vanillacommunity.com/discussion/comment/169761#Comment_169761
2021 T@B 400 BD, 2021 Lexus GX 460, Kansas City MO1 -
Ahh. Didn’t realize some people are referring to the older 400s where the duct was lower. Yeah, I can see how that could be annoying. Glad they moved that duct up.2021 400 BD
@manyman297 - Our 2021 has the bed's AC duct at head level. Isn't your 2021 at that same height or is nuCamp moving the AC duct up to the top again?
I have the 3 way fridge on my 2021 . I think I remember someone saying that if you have the 3 way the duct is head level and if you have a 2 way it’s higher?2021 TAB 400BD; 2015 Audi Q5
I'm losing my mind. You're right. I think your pillow threw me off as it looks like the duct is right at mattress height.rhyno said:@manyman297 - Our 2021 has the bed's AC duct at head level. Isn't your 2021 at that same height or is nuCamp moving the AC duct up to the top again?
I actually don't find its location an issue as long as the register is pointing upward. I'd rather have it there than up high. I find that when it's really hot I like to just point it straight at me to get cool quicker.2021 400 BD
