Battery drain w fridge even on shore power
I have a 2021 320 CSS and I am experiencing battery drain even when plugged into shore power.  I have a Battleborn battery and Victron BMV 712 battery monitor.  While driving with the fridge on we started the trip at 100% battery and after 7 hour drive arrived to campsite with 69% battery. Even with 4 hours shore power and only the fridge on we continue to have a 1.2 to 2.6 negative AMP and the battery went to 70% and now 69% and still around 13.22 voltage.
it seems like shore power is not causing a recharge of the battery.   I have the NuCamp standard converter.
Any suggestions are appreciated!
Thanks.   Jeff57
  • Sharon_is_SAMSharon_is_SAM Administrator Posts: 9,886
    edited September 2021
    The Norcold frig draws at least 4 amps when the compressor is cycling.  It is not as efficient as the Isotherms in the S model.
    Do you have a charge wire with your 7 pin harness?
    The converter will not completely charge a lithium battery.  I think you can get up to 85% recharge.  Solar will give you 100%.
    This will help:  https://tab-rv.vanillacommunity.com/discussion/14208/lithium-battery-change-converter#latest
  • BlueYonderBlueYonder Member Posts: 19
    Did you switch over from battery to shore power on the fridge?
  • MarcelineMarceline Member Posts: 1,646
    Thanks.   Jeff57
    Did you pre-chill the fridge from shorepower before you started your trip? If not, the fridge will consume a fair amount of power to get down to 40degrees and your alternator probably wouldn’t keep up. That would explain the initial drop. Do you hear your converter kicking on? You should hear the fan if its feeding power to the battery.
    If you wanted to get it more fully charged while on shore power, maybe you could isolate the battery & connect a charger with a lithium charging mode, like our Noco Genius 7200..
