Backup camera mounting
lkc001
Member Posts: 877
Hello all-- I got an aftermarket backup camera & need to mount it somehow in my truck. I have tried the magnetic phone mount with the sticky pads that comes with it. Then tried 3M VHB tape. Both have fallen off. Would like to keep from using a windshield mount as you have the cords dangling around. Any suggestions for a sticky tape that can withstand the heat in a vehicle or???
2018 Tab 400
If you're talking about mounting a video screen or cellphone on the dashboard, I've been most happy with a beanbag type mount that has enough weight to just sit on the dash & hold the screen/cellphone.
@BrianZ. Yes it's a video screen that came with the camera. Do you leave it sitting on the dash all the time? I'll check those out. Thank you2018 Tab 400
2016 Nissan Frontier SV 4x4 Crew Cab -
@lkc001, no, when not in use, I set it on the floor.-Brian in Chester, Virginia
@lkc001, Our beanbag mount is from an old garmin GPS unit, but vendors still sell stuff that fits it. I replaced the Garmin screen holder with an adapter that provides a standard 1/4x20 screw mount, then added a couple more adapters to fit my backup camera's 7" screen..
Here are the parts..
(1) ARKON SP-SBH-KIT-CAM Tightening Ring and Camera Head 17mm Swivel Ball Adapter Kit (Black).
https://www.amazon.com/dp/B00CMLX1NS$5(2) 2Pack ChromLives Tripod Nut Barrel Nut Connection Nut with 1/4''-20 Thread Hole for Articulating Magic Arms Tripod Rigs Replacement.$8(3) Camera Hot Shoe Mount to 1/4"-20 Tripod Screw Adapter,Flash Shoe Mount for DSLR Camera Rig (Pack of 4).$9
(I had to trim this part #3 to fit the slot.)
It works quite well.-Brian in Chester, Virginia
@BrianZ. Thank you! The pics also help slot.2018 Tab 400
We used this mount that fits into a cup holder. Adjustable every which way and easy to monitor in and remove if necessary. We had previously used a bean bag set up but found we liked this better. https://www.amazon.com/gp/product/B07GB64H18
2021 320 S BoondockSubaru Outback XT and Honda PassportDes Moines, IOWA!
- 917 Introductions
- 404 Service/Maintenance & Recall Notices
- 74 Teardrop Groups & Links
