Fan-Tastic Vent failure
OlyCampers
Member Posts: 23
Greetings-
The fan/vent in the bathroom of our 2020 T@B 400 BDL stopped working this weekend. No warning, no electrical smell or obvious broken wiring connections. Has anyone else had issues with their Model 600 EZ-Breeze fan? Thanks!
2020 T@B 400 Boondock Lite behind our 2014 GMC Sierra. Homeport is Olympia WA USA.
The fuse holder may have come loose. Recheck that. Happened to me last year.2022 T@B 400 BD
2019 Ford F-150 3.5L Ecoboost with Long Bed -
@JohnDanielsCPA Thanks for that tip. While the fuse holder on the Fan-Tastic fan in the main cabin is visible, I don't see a fuse on the fan in the bathroom. Can you point me towards it?2020 T@B 400 Boondock Lite behind our 2014 GMC Sierra. Homeport is Olympia WA USA.
Check the fuse panel on the converter.Rich2019 T@b 400
@OlyCampers, if you use the search box (upper right of this page) and type in “T@B 400 fan” you will find a number of other posts concerning the problems with this fan.The “normal” solution is to upgrade your other roof top fan with a 10 Speed Fantastic Fan or a MaxAire 10+ speed fan. Then you replace the current bathroom fan with the 3-speed fan you removed. If you have already updated your main roof top fan, a three speed Fantastic fan would last a long time in your bathroom.Verna, Columbus, IN
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
