I'm wondering if anyone is running their Cool Cat on an inverter/generator. If so what size generator? I tested the amperage at startup with an in-rush meter and got 48 amps which don't seem possible. Running amps was about 9 amps. I want to run the Cool Cat on a generator but need to know what size. I believe the running watts would be a little over 1000 but I'm worried about the startup amperage.
0 ·
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
The 2200 watt honda generators (or similar sized others) operate the current models of Coolcat in the 400, but with a softstart installed.
Otherwise, any 3500 watt class of generator will work just fine - but at the expense of weighing 100lbs.
I use a Champion Dual Fuel 2500 on Propane with the SoftStart RV installed, and it works perfectly - even at altitude.
2020 Tacoma TRD Off-Road
