Tab 2015 stove top
Does anyone know what the squiggly white line on propane stove top control  is for? I know big and small flame is flame height.
  • Mellow_YellowMellow_Yellow Member Posts: 354
    Hi @LittleBee - Might be helpful to post a photo and confirm that you have a Dometic stove top. The control knobs on my 2014 version of the Dometic have 3 positions, left to right: light, high flame, low flame.
    When you push the control knob in, turn it to the "light" position to light the burner. Hold in for 3 to 5 seconds, release the knob and then move to a position between high and low.
    Hope that helps!
  • ScottGScottG Administrator Posts: 5,627
    If it's like the stove on my 2015, the squiggly is a lightening bolt. That's the position you set the knob as you push it down and hold it while you light the burner with a match or striker.
