I had the same issue and this was my fix. The vent to the outside is both exhaust and intake. There is a metal flex tube for the exhaust that is mounted inside a plastic intake hose. I discovered that the plastic hose was vibrating and striking the metal exhaust hose. (The rattling noise). I loosen the clam on the plastic hose from the unit and pulled it as far as I could on the sleeve it was mounted to, giving me more clearance, and then thightened it up. No more noise! I would like to install a longer hose to get more clearance but the dealer has not been able to get me one as of yet. Hope this works for you and others.
0 ·
There's another thread going now about adding in-line a propane regulator to resolve the root cause of the problem -- the Alde runs too rich at higher altitudes. So even if you quiet it down, it's still not running right. Keep an eye on the exhaust port -- if you see any black soot building up, this might be problematic down the road as the entire burner assembly inside the Alde is building up the black carbon too.
2014 T@B CS Maxx
Martha Lake, WA
Alde should have provided that as part of their unit.
