Dutchman 5 Gallon Water Storage Container
jjenkins130910
jjenkins130910 Member Posts: 3
Hello, I need to replace the 5 gallon water storage container for my 2005 tab, I have googled for hours and can not seem to find a similar product that allows the sink faucet water pump to draw water from the container. Can anyone offer any suggestions as the where to find such a product?
  • Michigan_Mike
    Post up some photos.  We have many innovative members onboard and there has to be an alternative and solution to your problem.  Maybe the pump needs to be replaced?
  • Santo
    Santo Member Posts: 15
    I just purchased a 2006 tab, clamshell. I am confused about the potable water tank vs the reservoir. My previous trailer, a little guy, only had a reservoir. What is the connection between the potable water tank under the sink and the reservoir? Where do I put the antifreeze to winterize it? Thank you! Signed newbie
  • Santo
    By the way, it is a dutchmen tab
    If I am not mistaken, the DM TaB only had the 5 gallon water container mentioned above.  Do you have 2 different tanks?
  • Santo
    There's a place on the outside to hook up a hose, maybe that goes directly to the potable water tank. I just assumed there was a reservoir. I am waiting to hook up a hose to see where the water goes.
  • Santo
    Still I don't know where to put the antifreeze to send it through
    Here is a quote from the other thread that you posted to:
    “Water system is manual fill of 5 gallon container, or hook up at site if external fittings installed. You may also have a 12V water pump for delivery from container.”
    Sounds like you can hook up to city water or use the 5 gallon container.  When you say reservoir do you mean a fresh water tank?
  • Verna
    Verna Member Posts: 6,876
    As I recall, the gray water system on the Dutchman T@B’s is a screw on fixture for a garden hose under the front of the T@B and you need to provide your own gray water reservoir.
    Some use an oil change tub that can be closed, and there are 6 gallon gray water reservoirs that you can add a hose attachment to.  @BrianZ just had a writeup about a new 6 gallon gray water reservoir he has been using.
  • BrianZ
    BrianZ Member Posts: 1,770
    edited July 2023
    UPDATE:
    Sorry, but this tank is no longer available.
    If you need a gray water tank for attaching a garden hose, I have one of these 6 Gallon tanks that I'd give away for the cost of shipping.. (including a new & more secure bayonet cap with 4 latching hooks to replace the original shown here with only 2)..
    I will be using a different model with wheels, so don't need this one anymore.
    Here's the source link..
    Tote-N-Stor 25951 Portable Waste Transport - 6 Gallon Capacity https://www.amazon.com/dp/B0085KGOF2
    And the new replacement cap I'm including..
    Camco Durable Sewer Cap with Hose Connection- Caps the Sewer Connection to Prevent Leaks, Easy Install and Simple Use (39463) https://www.amazon.com/dp/B000BQKBP2
    Send me a private message if interested.
  • Efortuni
    Efortuni Member Posts: 7
    Hello! Chiming in years later. I have a 2005 tab. So this gray tank can hook a hose to it? It is currently unvail so if you still have it I would def purchase! We have used buckets and such but would be better to have something like this .. thanks! Photo from our last trip
