I tapped into the 12v line that used to power the outside TV (I removed it) in order to install a red LED light strip under the top cabinets in the clamshell and a warm white LED strip inside the trailer where the cabinets meet the roof. The indirect lighting has been a huge improvement.
4 ·
Red LED strip: https://amzn.to/2YQurRM
Warm White LED strip: https://amzn.to/3DEXGFM (I actually had leftover strip from an earlier project at home)
I suppose that you could use RGB strips, but I stuck with single-color strips as they're easier to connect.
On/off switch: https://amzn.to/2YJIXuH
Connectors & wire: https://amzn.to/2YJIXuH
Silicone channel (used to cover warm white strip inside): https://amzn.to/3AyEmIl
I'm not quite satisfied with the on/off switch inside, so I'm going to try this:
Dimmer: https://amzn.to/2YJebSJ
2019 320 Boondock Edge - Sold Jan 2022
