LED strip lighting
I tapped into the 12v line that used to power the outside TV (I removed it) in order to install a red LED light strip under the top cabinets in the clamshell and a warm white LED strip inside the trailer where the cabinets meet the roof. The indirect lighting has been a huge improvement.
  • Slackers
    Slackers Posts: 490
    Thinking we may do something similar.  Any links to products you used?
  • Marceline
    Marceline Posts: 1,767
    edited October 2021
    Any cuttable 12v LED strips would work. Here's what I used:
    Red LED strip: https://amzn.to/2YQurRM
    Warm White LED strip: https://amzn.to/3DEXGFM (I actually had leftover strip from an earlier project at home)
    I suppose that you could use RGB strips, but I stuck with single-color strips as they're easier to connect.
    On/off switch: https://amzn.to/2YJIXuH
    Connectors & wire: https://amzn.to/2YJIXuH
    Silicone channel (used to cover warm white strip inside): https://amzn.to/3AyEmIl
    I'm not quite satisfied with the on/off switch inside, so I'm going to try this:
    Dimmer: https://amzn.to/2YJebSJ
  • Slackers
    Slackers Posts: 490
    Thank you for the links and quick response!
  • CrabTab
    CrabTab Posts: 457
    edited October 2021
    So smart to use red outside @Marceline. Easy on the night vision.
    2019 320 Boondock Edge
     - Sold Jan 2022
  • Marceline
    Yes, that's the idea.
