2018 Tab400 Valve Configuration
I have yet to find a diagram that matches or instructions that are directly applicable to the valve / plumbing configuration of our 2018 Tab400. Even the dealer wasn’t 100% sure of the purpose of each valve.
I have numbered them 1-4 in the attached image. Here are my attempts at identification:
#1 - low point drain, hot?
#2 - this seems to duplicate the Alde relief valve (as both valve #2 and #4 are part of the same run). When I opened it up to winterize, hot water came out.
#3 - low point drain, cold?
#4 - this is the “Alde relief valve,” This drains water out of the boiler correct?
Can anyone please help me verify?
We winterized using the blowout method, so I think we’re properly winterized, it would just help me to know the purpose of each of these valves.
Thank you so much!
Tony
    qhumberd Posts: 872
    Try this video from Patrick of Travels with Delaney on drain valves. It shows your configuration without Alde Flow in a 2018
    https://youtu.be/38sqyG5-ow4
  • Denny16
    Denny16 Posts: 5,430
    edited November 2021
    Correct, the three valves (1,2,&3) are your low point drains, as follows:
     1- Hot water lines to sinks and shower
     2- Alde hot water tank drain
     3- Cold water lines to toilet, sinks and shower.
    The yellow valve (No. 4 in your post), by the Alde heater, is a pressure overflow valve, you do not need to open this to drain the hot water tank, as low point drain valve #2 does this, and is easier to reach.
    That video was super helpful @qhumberd, thank you, exact same config!
    Denny16 said:
    Correct, the three valves (1,2,&3) are yiur low point drains, as follows:
    @Denny16 thank you so much for confirming, I really appreciate it!
