I took my T@B out for the first time this year and noticed that it was squeaking pretty loudly on this trip. This was something I didn't notice last year. Are we supposed to do any kind of annual "grease jobs" or maintenance that might prevent this? Does anyone have any idea of what it could be and should I be worried? Thanks!
                0 ·
I asked because I remembered my dad taking the car in to lube the chassis (which tells you how old I am) so I wondered if we're supposed to do something similar to the trailer?
Nothing on the T@B needs lubing except the bearings need to be greased at certain mileage markers (6,000 miles as I recall).
WD-40 is actually a solvent and a water displacer, rather than a lubricant, and it will evaporate. Silicone spray lube is a light duty lubricant, and is better for things that don't wear too hard.
You should grease your ball and hitch to limit wear(even though it ends up being a potential pants stain). Apply a thin coat of automotive chassis grease whenever it looks dry. You can put a ball cover on it when not in use, to keep the grease off the pants leg.
PXL, I think all trailers have a ground wire for the lights etc. I used to think the hitch was a ground too, but it doesn't really make much sense with how poor the connection would tend to be.
I'd like to look into that greaseless tow ball, myself. Any idea if they have any more tendency to fail than a normal ball?
As for annual lubes, on the LG Tab, your wheels should be checked and lubed at least annually. At a minimum, I would jack up each side and spin the tire to see if there's any noise or looseness.
Also, if you have the LG surge brakes, annually make sure that mechanism is moving freely, especially after exposing it to winter road-salt.
Hi Chan. Thanks for all the helpful info. I think I'm going to go with the greaseless tow ball that Sandra suggested. I found it on Amazon for about $20. As for the WD-40 silicone spray, the only reason I know about it is because I use it!
I wonder if, for me, it was a case of too small a ground wire in the 4 pin connector, and I was just ignorant about it.
Where's Sandra?!
