Filling Fresh Water Tank
2022 Tab 320s bd arrive at campground and notice posted that all water at campsites is turned off. But an outlet is available near the entrance with a sign to fill your tank before going to your site.  Do I just connect a hose to the left inlet on the Nautilus and open the tap until full?  Should pump be running?  What position for the handles?  I tried to get answer from looking at the many posts, but this newbie is still confused.
Thanks
  • MuttonChopsMuttonChops Member Posts: 1,751
    Towhee said:
    2022 Tab 320s . . .
    Place your Nautilus Handles in the City Water, Fill Tank Position.
    Water Pump Off.
    City Water pressure will fill the the Tank.
    Picture from Nautilus 2.5 manual:
    Adventures:  55   Nights:  376  Towing Miles 46,920
  • manyman297manyman297 Member Posts: 1,380
    edited December 2021
    Once you see/hear water coming out of the overflow tube under the trailer then you’ll know when to stop. Don’t rely on the interior instrument panel to tell you when it’s full.
    2021 400 BD
    2020 Tacoma TRD Off-Road
  • TowheeTowhee Member Posts: 54
    Ok That's what I did except I relied on the instrument panel to indicate when the tank was full.  After selecting Dry Camp at the Nautilus I tried the pump which did not produce any water anywhere.  Later when I drained the FW tank I got only a gallon or so even though the panel said full.  I'm guessing not enough to prime the pump.  Just to be sure, I should only use the left inlet on the Nautilus to siphon anti freeze or dilute bleach solution, right?
    Towhee said:
    . . . Just to be sure, I should only use the left inlet on the Nautilus to siphon anti freeze or dilute bleach solution, right?
    Ans: Correct.
    Suggest you review PDF file attached to first post of this thread
    And Nautilus User Manual . . . available on-line
    @ MuttonChops. Thanks, I think I finally got it.
