Someone might know more about these: but what kind of poles are they? Fiberglass segments with "shock cord" holding them all together? There are several companies that sell individual pole segments if you can sort out the diameter and length, and it isn't hard to replace broken sections. They can also build entire poles for you with, again, the diamter and length you need. There are other sources in this thread you can check out.
