Thermarest Archroom tent fit 2014 T@B?
Injapan1
Member Posts: 1
Hello,
I need everyone's help. I am in the military stationed in Germany, but am getting ready to move to Colorado Springs:) I have been researching 2014 T@B trailers, but came across the Thermarest Archroom tent while looking at photos online. This tent seems perfect!
Now, for the questions:
Will the Archroom fit the new T@Bs? (Awning rail issue?)
Is there any place I can still order one?
If not, anyone have a nearly new one for sale?
Thanks so much for the help. Can't wait to explore Colorado!
Kris
Yes, they will. The newer Little Guy T@B's are built to the same dimensions as the older Dutchman T@B's. You may also want to look at some of the PahaQue products that are designed specifically for the T@B.
Sterling, VA -
The Thermarest will fit the LG T@Bs but they're no longer made and are very difficult to find. Paha Que makes a tent room, however. The Thermarest was only made in yellow, but Paha Que will customize to match your T@B.Crystal & Daisy, a yellow 2007 T@B Q previously towed by a 2008 Jeep Liberty, and currently towed by a 2016 RAM 1500.
The first general Paha Que was based upon the EZ-Up canopy frame, and you can zip on walls and/or screens. It's no longer made either.The second generation Thermarest is like my photo above, except that the poles have clips and you don't have to thread through the long sleeves.Crystal & Daisy, a yellow 2007 T@B Q previously towed by a 2008 Jeep Liberty, and currently towed by a 2016 RAM 1500.
Both the Paha Que and Thermarest screen rooms have "skirts that cover the wheel wells and underside of the T@B. The skirts come right up to the door threshold. That works for older T@Bs, which didn't have a pull out step. For newer T@B owners, has anyone had any trouble pulling the entry step out with the screen room installed?
David -- Saint Paul, MN
2015 T@B-L "Silver Dr@ggin" towed by 2015 Kia Sorento V6 "Don Poulan" -
- 916 Introductions
- 72 Teardrop Groups & Links
