Timbren Axle-less suspension on a 2006 T@B T-16
SS_Minow
Member Posts: 2
I wanted to check and find out if any folks have installed Timbren axleless suspension on there T@B? I have a 2006 T@B T-16, and plan on this project. But wanted to get some feedback.
Thanks-
(Title edited for search purposes. Moderator)
Thanks-
I don’t recall seeing anything about installing Timbren suspension on a T@B but there are several threads on the T@G forum that discuss it. That might be a starting point. It looks like an interesting option.2021 320S BD
2017 F-150
Coeur d'Alene, Idaho1 -
Thanks Wayne; appreciate the feedback. I'll check it out👍0
I wonder if the light weight C channel frames on the older Dutchmen T@B is up to the task. When I mounted a clamp on spare tire carrier to the frame just in front of the propane holder, I was amazed at how much the frame would twist bouncing the tire around when I bumped the tire by hand. I decided against it. I think these frame rails need to be linked together with the axle spanning them - we all know that our floors aren't strong enough to hold things together.
I could be wrong but I felt I should say something.
Good luck.2006 T@B1
