RZRBUG
Member Posts: 890
I know there have been three or four discussions on generators and I have scanned through them all but couldn't decide the most appropriate one for this. I finally bought a Honda EU2000i yesterday. While trying to get familiar with it and reading the manual, I found this:
"DC Receptacle: The DC receptacle should ONLY be used for charging 12-volt automotive type batteries. The DC charging output is not regulated. This means that the charging output does not decrease as the battery reaches full charge. Check the battery voltage frequently while charging to prevent overcharging the battery."
I decided to post this because I saw more than one person in the forum say they wanted to use the generator to recharge their batteries. Apparently you can damage the battery if you don't keep a check on it while using the Honda generator. I haven't tried it, but I would assume you could put some kind of regulator between the generator and the battery to control the charge, like a Battery Tender.
Happy Trails Y'all
Thanks for for the heads up on the generator charging, as I was not aware the DC output did not have a charging regulator.
