My 2019 - 400 has a tongue wt of 400 lbs. and has been confirmed by weighing. I am considering two options to reduce it.
1. Extend the trailer hitch. The distance from the centre of the axle to the ball is about 11 ft. So, 11 X 400 = 4400 ft lbs. If I increase the distance from the axle to the ball by 1 foot; the new tongue weight becomes 4400 / 12 = 367 lbs.
2. Move the batteries further aft. The existing tongue wt is 400 and the moment on the hitch as noted above is 4400 ft lbs and with the batteries in the factory position. If the batteries weigh 130 lbs and if moved 2 ft aft, that moment is 2 X 130 = 260 ft lbs. The new tongue wt becomes 4400 - 260 = 4140 / 11 = 376 lbs.
Hopefully this methodology holds water. The reductions calculated I’m afraid hardly seem worth the effort let alone the cost, but perhaps useful information.
Ciao
400 - 2019
St Catharines, ON
0 ·
Extending the ball mount forward would require an extensive modification to the frame that would need to be pretty beefy to handle the extended moment arm. All that additional structure would add to your tongue weight, possibly entirely negating any reduction.
For moving the batteries aft, you'd need to ensure the floor structure at that aft location could handle the weight.
You live near one of North America's best hitch shops and they are specialists with such issues. Contact them for advice, we did several times over many years towing and their advice has been invaluable to our towing experience.
https://www.canamrv.ca/towing-expertise/contact/
Doug K
Nucamp 400 on order and 2021 Honda Ridgeline BE
Battle Lake, MN and Mesa, AZ
Minnesota and Arizona
Ontario, Canada
2018 Tab 400
Ford F150 2.7 Lariat
The T@b 400 at full load is 3900 lbs. If you loaded at full load (and it's surprisingly easy to do), towing stability would require a minimum of 390 lbs tongue weight (10% of total loaded trailer weight). So it will depend upon where you put put your gear, supplies, etc in the trailer to maintain sufficient tongue weight for stability (minimize dangerous sway conditions).
Especially on a medium or light size SUV or truck, taking load off the tow vehicle's front axle by putting load behind the tow vehicle's rear axle (trailer tongue weight plus any load in the tow vehicle placed behind the tow vehicles rear axle) will decrease the steering tires contact with the road.
Also, it is best to maintain the heaviest weight in the trailer near the trailer's axle. Placing weight far behind the trailer axle can increase any sway leverage on the hitch pivot point, and then transmitted forward as yaw to the steering axle of the tow vehicle. I don't think two lithium batteries would matter so much, but then there is the loading of gear into the trailer that may increase the risk of a rear-heavy trailer.
It is so very important to get some weights at a truck scale to see where your axles are loaded when shifting weight around. Good to know the unloaded weight of the tow vehicle's axles (especially the front axle relative to stability). Then take your fully loaded two vehicle and attached trailer to the truck scale to see that all your loaded axle weights are within limits, and that your tow vehicle's front axle is not dangerously unloaded. Generally speaking for these lighter tow vehicles, it is usually good to have the load added to the tow vehicle equally distributed to its axles. Some 1/2 ton pickups will state in the owner's manual to put no more than 50% of the removed weight back onto it's steering axle with a weight distribution hitch (because they are already heavy in the front compared to the empty box in the rear). You don't want oversteer or understeer, but a balanced load.
Doug K
First, I would never tow a trailer loaded to its max axle rating with a WDH, or not, not a good situation. Next I would be careful about using a WDH with a small trailer and a large per TV. For a WDH to work properly, the trailer and TV need to be equally matched. Just like you would not pull an Airstream Classic with a compact vehicle, I would not tow a small trailer like thenTaB using a WDH with a large TV like a 3/4-ton truck or some of the so called 1/2-ton trucks.
So I can carry more stuff; perhaps bikes, or an extra propane tank, etc.
My TV, a Subaru Ascent cannot be fitted with a WDH and does an admirable job of towing the 400. So that is out !
Extending the hitch is a fairly straight forward alteration and would not add much weight to the frame if engineered properly. Moving the batteries as shown in this thread also seems a reasonable approach as long as there is enough battery weight and distance to reduce the moment at the hitch.
St Catharines, ON
