@021 T@B 400 Prepared for 4th camping trip. Turned refrigerator on shore power to start then switched to propane which also worked fine. Took unit to storage for overnight. When I dropped it off I had no power to refrigerator. Everything else worked fine. Hooked back up to take home to empty ref and ref works as long as it is plugged into TV
Crazy!!! I checked all fuses. Will not work on shore power or battery, only when plugged into Tow Vehicle. Any suggestions???
Your final statement . . .
Is odd. How are you defining 'Fridge Works' - - - the Control Panel is active or you have waited long enough to observe cooling?
I suggest . . . now that some time has past you start over confirming Fridge Power Source operation. As No single fault point comes to mind that allows Fridge operation on TV +12VDC only.
For reference a simple trailer wiring diagram:
Also should be using my surge protector even at home. Hope this helps
